dry nitrous reccomendations
MPS has a great little dry package with a switch swapper for nitro on the starter button and purge or shifter on the horn button
(rescuefighter @ May 25 2007,16:47) MPS has a great little dry package  with a switch swapper for nitro on the starter button and purge or shifter on the horn button
+300
This is the kit I got, it uses the thin plastic tubing not the braided/will cut through anything it rubs against hose! Also went with the dual nozzle upgrade to get a better spray pattern.
I had the NX dry kit and was very disappointed. I've got a Cold Fusion wet kit now and love it. I would say save up a little extra and do the wet kit, it is worth every penny. There is night and day difference between my 40hp dry shot and 60hp wet shot, even if you only spray 40hp thru the wet kit it works great.
Turbo
