OB_Dirty Pete
It's the 007 "Full Akrapovic system with modified airbox and stock air filter" that carries a warning from Dynojet to the effect that they do not recommend modifying the airbox, and that on map 007 the low end has been leaned out which may result in overly sudden low end response AND that, if you get that effect from 007 and don't like it, you should revert to map 006 despite having the airbox mod.
