dyna 2000
OB_bigabusa
I am working on a CNC'd starter cover to suit a Dyna ignition for anyone running carbs or nitrous, is there anyone out there who has made one already?
I don't think so. Everybody seems patiently waiting. What do you think of the Nitrous Express system that is out now? The reason I ask is I was asking you about the nitrous on your bike last summer.
My apologies BigaBusa, I took a glance at your profile and saw that you ARE in fact TTS....Mr Richard Albans I presume??
I had sent one set of cracked cases and a OEM replacement for cnc reproduction in a stronger billet aluminum, but then "heard" someone else was doing this so the project got tossed on "hold". You dont need everyone reinventing the wheel, it is usually cheaper to purchase an ready made part than to pioneer your own.
I also went to a gear shop for construction of new starter gears from an upgraded material. The engineer claimed he could make a stronger gear from a better material, but also remarked the OEM gears are not made from poor materials.
They could be improved upon but as anything this costs money and a limited market the initial set up costs have to be absorbed somewhere.
Yosh-USA mentioned back in september 99 the higher compression pistons (12.3+) tend to aggravate the problem of the broken cases and crank/starter clutch spline failure.
my prototype case will be ready on tueday. when i have checked it out the first run will be of 20. with the exchange rate it ain't going to be cheap, approx. 260 USD. I will try and get a photo posted but my internet/digital camera skills are not the best.
SORRY FOR THE DELAY ON THIS. The CNC company I gave this job to has come up with every excuse under the sun for not getting this job done. BUT it is now in the final stage with the first 10 already 3/4 machined. I should have stock by the end of this week.
