HAYABUSA1340
What do you guys and gals think about DYNA BEAD nomore wheel weights
So centramatic is diff than Dynabeads correct ?
Probably not an issue and I'm sure others have speculated but at high speeds, 170+ could these balls blow through a tire?
Problem I have is I mount my own tires and need to use some lube. You cannot use dynabeads if you apply any lube to the inside. :/
Use vegetable oil paste. It comes with tire changers when purchased and works perfectly on removal and installation of old and new tires, it drys so it wont effect dyno beads at all.Problem I have is I mount my own tires and need to use some lube. You cannot use dynabeads if you apply any lube to the inside. :/
