dyno question
ajm
Does tuning your bike on a dyno allow you to put the performance where you want it? Like down low for riding twisty roads and having the power down there or does it give you better performance overall and no where specifically? Assuming full system pc usb 3.
ajm
It's optimized for the entire RPM range over certain throttle positions. The tuning is designed to get a perfect AFR anywhere in the throttle at any RPM range, so it helps all over.
yes, it allows you to program the bike to your specifications and how you ride!!
