dyno results of airbox mod and pc2 on stock busa
Hey, do you plan on smoothing this box up any?
One good thing to know about doing these box's is that you need to treat them as if you were Porting a head!
Dennis, is this one that you had epoxy on at one time or another?
Where are you putting your filter at?....I would do filters over the inlet tubes if I were going to use any.(not!)
I don't think theres any need to speading a filter over the area that you just removed?
I cut the ledges off the inlet(outside box area) tubes, the ones that have the cheap foam stuck to, on My box.
I'm looking to make some extenions to go between the airbox and the frame tubes so you can have a easy in, easy out. I've been doing the Duct tape(half asss)for the time being.
Dennis, it would be nice if you could show one of your completed packages!
I know your not done with the box in the pic, but are you sure that you only want to charge $75.00???
You know that if you come up with some Maps to go along with these box's, you could charge $150 to $200 easy!(still a good deal!)
Thats pretty cheap for that kind of gain.
No disrespect to Dennis, but I would not carry through with this Mod unless You had every intenion on remaping for it!
Theres no reason on doing any Mod if your not going to go the right way the first time.
I guess this is My 2 cents?
its my test box i posted pics of customers box and you guys could not tell/so i gave ya one you could.i have maps for the 99 now i'm doing the 2000.i run a filter over entire hole.you will restrict the flow significantly if placed anywhere else.with and without filter it dynos exactly the same time after time. i charge whats fair not what i can charge.i want everyone to go fast!i will supply maps for free with my mods!ran this mod for nearly a year!
[This message has been edited by THE MOTORHEAD (edited 08 April 2000).]
<<i want everyone to go fast!>>
Well in that case....I need a good Nitrous System....and maybe a Turbo, does this mean you'll buy them?
I sure hope so!! :)
