in my opinion, I would get the oil out of the engine at about 30 miles. The reason why is because the parts in your engine were sitting on a factory shelf/bin for months before being assembled. You have to think about how an engine comes together. Parts are mailed, packaged, stored, and exposed to the elements. I dont know if you have ever been in a factory, it's dirty, oily, dusty, and usually pretty filthy. Bottom line is this-
your engine is packed with grime, dust, sand, cloth fibers, metal shavings, cardboard, and a ton of other debris.
I use to sell hydraulics to massive factories, where filtration is everything. I have a kit that I kept from PALL filter corporation that allows me to pull an oil sample, funnel it through a 5 micron paper filter, and examine the debris left over. You wouldnt believe the amount of garbage that was left on that filter from less than a 1/4 cup of oil! That oil was filthy!!! 30 miles and get it out of there!
The break-in procedure is everything. Taking such precautions makes a difference in the extreme long run. Changing oil @ 30 miles can be the difference between your engine lasting 30,000 miles, and lasting 40,000 miles before losing compression. That's just my 2 cents
Mike
