hi all
i have questions regarding the shifter function in ecu editor
is the switch in question just a straight connection of the two wires (with a resistor ),does it cut out the engine while for the time the wires are connected or does it just cut it out for the selected time even if the wires stay connected?
if i program the ecu with ecu editor to control my 50 hp dry nitrous (revs,fuel at wot can i still use the shifter function if so should i use both fuel and ignition cut and how long should the cut be made for
is it safe to use it with the pair valve controlling the nitrous or will it still let the nitrous into the air box, if it does is this ok or risky
any help is appreciated
Dave
Dave
