If you want to buy ecu editor, then yes. It's just a matter of clicking a few boxes.
If you buy a bench flasher you can remove the ecu and plug it in directly(there is no need to do this).
Otherwise you install a 2 wire jumper harness between the black ecu plug, and the black yosh plug(it stays on the bike and is nearly invisible unless you're looking for it), all are easily accessable under the driver's seat.
Both ends of the harness plug into empty locations on each plug. Very quick and easyto do, and directions clearly show you which wires go where.
Then, ecu editor plugs into the black yosh plug, and the white diagnostic plug. The other end to your computer or laptop.
Open a new file, click some boxes, wait about 4 minutes for it to flash, and done.
A much better bike, and for $200, ecu editor is the best bang for you're buck performance you can buy.
Cycle Connections is in Gaithersburg MD, and they are an ecu editor tuning shop.
I cannot comment on their tuner's ability, but hopefully someone here can. As Got-Busa said above, the tuner is the most important part in getting a good tune. It's also not about a peak hp number on paper, it's getting a smoother, better performing bike.
If you choose to get an ecu editor dyno tune anywhere, you do not need to buy ecu editor. You will only need the 2 wire jumper, which is $10 from boostbysmith. Depending on what the shop wants to charge for this, you may want to buy and install it yourself. As said, cheap, quick and easy.
Then they just plug in, tune, and that's it. No need to buy a Power Commander either for a shop that already tunes with ecu editor.
If you can't buy ecu editor or get your bike dyno tuned at the moment, I remove the restrictions and make the changes that don't require dyno tuning(I have a bench flasher)and I never touch an air/fuel or ignition map. I do them free for org members, just send me a paid return shipping label. I flash them the day I get them, and they go out the next day.
I've done 10 gen2 Busas in the last couple years, as well as my own and my B-King.
No pressure either, just an offer. And...I'm 'currently' not scamming folks and selling parts on ebay
And unrelated
The white diagnostic plug that ecu editor plugs into is where you check for trouble codes(you can do this with or without ecu editor too).
Also very simple. Gen2 Busas are excellent bikes with few problems, but it's good to know where to start should any future problems ever arise. Check it out.
The service manual is free here too if you haven't found it yet.
https://www.hayabusa.org/forum/general-bike-related-topics/166911-how-diagnose-fi-light-obtain-ecu-fault-code.html
https://www.hayabusa.org/forum/general-bike-related-topics/158939-service-manual.html
