I did my 2001 at the begining of last year. 2002-2007 stator hub and ECU is all you need...and maybe a gasket for the stator cover. If you want to reflash the ECU Greg is your friend (check boostbysmith add on this site).
Search this site and the other .org site for information. Good luck.
you will need to remap the bike if changing, going from earlier stuff to 02-07 the bike will be lean. if you are swapping so that you can ecu flash, just make sure you have ability to know air fuel etc
