Whoa... hold up...!
I wasn't planning on using the map from another bike. I just think my PCIIIUSB is close to dead and I have my own map to start with.
When I say dead... it may have a bad USB port (or could just be a driver), but I cannot change anything in it. I have to assume the map is actually working though (bad idea?).
That PCV looks like a plan, but I'm still so new to this that the suggestions of just replacing the "3" and uploading my current map seems sound.
A little later, if I get a PCV with the boost/temp thingy (intentionally making fun of my ignorance), I can keep the PCIII loaded with a really safe map to use as a backup in case the PCVT fails...or just sell it again.
I'm still learning the capabilities of all this stuff and I don't have a plan, but I do have a vision...
That vision is 3 levels of boost/fuel combo. One for 87oct-6lbs (for traveling), one for guaranteed 92oct+ with 8lbs (for normal riding), and one for "race" being 110oct+ with 10lbs boost.
This bike by the way was set up for 350hp on C16 with 15lbs when I got it... just for reference.
I would like to be able to switch these on the fly using the right controller (still working on that info') depending on the fuel I know I have in the tank.
The PCVT looks super, but if I got one right now and installed it, I would have no clue if I did something wrong, or said another way... how to set it up right the first time.
Ecueditor seems popular, but being able to fuel off psi in a gen1 seems like a great thing to have and the consensus is that it won't do that, plus only certain people are familiar with tuning it and I'm already in an area with limited resources in that regard.
If the PCVT (errr.. PC-5-Turbo) can translate PCIII maps, that's even better because I could get this used PCIIIUSB and get the bike running as well as it can... then use that as a base map on the PCVT. Since ecueditors seem cheap, I'll add it anyway even if it's not the main modifier of fueling. It sounds like it will do ignition timing so.... ya.
Terri from Mr. Turbo says he'll help me adjust a few settings on this map, so I'll start with that.
Does that sound like a good path?
Thanks
Sean
