Hey... Not so sure for EGT's on 4-stroke bikes.. but I have used them extensively on 2 stroke snowmobile applications when racing. Like others say, useful for detecting a problem early. Though as good for tuning, at least on 4strokes... They run way different for temps, depending on the installer, applications, kind or probes, and where you mount them. Not sure what you planning, but The only time I beleive they are useful is when you monitor each cylinder independently. (I know some people put them in a Y pipe or interchange locations to monitor 2 probes for 4 cylinders... not very useful IMO). If you do use them, do some good research as to where to put them, and once you get them there, only pay attention to YOUR numbers... i.e. someone will say you are running cold at 850, but if you are mounted farther away from the exhaust valve than them, 850 may be hot for you.. Just my 0.02.
