dewie
I have a 07 bus and it is modified for me with landing gear cause I am a paraplegic. I have some extra electronics on it like the actuator to run the landing gear, Pingel shifter, I have a back up camera made for cars pointed at the landing so I can see the gear while I'm riding. I've been having tons of issues with the Pingel shifter working consistently and was trying to figure it out. I hooked up the battery and had a massive short that makes no sense.
All the lights work on the bike, all the fuses are fine including the main fuse under the tail, but the fuel pump doesn't turn on when you turn on the ignition, no back up camera, no actuator for the landing gear and it has its own in line fuse which is fine, Pingel shifter pops fuses the instant you put it in.
Its a brand new battery, all the fuses are fine, did I cook my ECU? Then again the shifter, landing gear and camera doesn't operate thru the ECU and is wired straight to the battery..
Frustrated
Frustrated
