I have failed this thing i know 20 times now. Its a test i have to take online for work and i have a feeling a couple of the answers are wrong but here is the test give me some imput you electrical guys
1: Technician A says that when current flows in a circuit, voltage drops across each resistance in the circuit.
Technician B says that the resistance of most conductors decreases as temperature increases.
Who is correct?
A. Technician A only
B. Technician B only
C. Both Technician A and B
D. Neither Technician A nor B
2: Technician A says that current flow in a circuit is directly proportional to the voltage applied.
Technician B says that current flow in a circuit is directly proportional to the resistance in the circuit.
Who is correct?
3: A light bulb in a circuit is observed to be dim.
Technician A says that current flow is lower than expected, and a possible cause is high circuit resistance.
Technician B says that current flow is lower than expected, and a possible cause is low voltage.
Who is correct?
4: Electrical power is measured in Watts, and is calculated by multiplying volts times amps. True or False?
A. True
B. False
5: The resistance of a wire increases as its diameter decreases. True or False?
A. True
B. False
6: A fuse in a circuit has blown. What is the most likely cause?
A. The circuit has too much resistance.
B. The circuit has low voltage.
C. Lower than specified circuit resistance.
D. There is an open in the circuit.
7: Technician A says current can be measured by connecting a meter in series with the loads in the circuit.
Technician B says current can be measured by connecting a meter in parallel across the component.
Who is correct?
8: Technician A says that when measuring current, power to the component or circuit must be turned Off to avoid false readings and to protect the meter and meter fuse. If necessary, isolate components from the circuit to ensure an accurate measurement value.
Technician B says that an ohmmeter uses a battery to pass a small current through the component or circuit to measure its resistance.
Who is correct?
9: Resistance in a circuit is measured in:
A. Amps
B. Volts
C. Ohms
D. Watts
10: Ohm’s Law says that it takes one volt to push one amp through a resistance of one ohm. True or False?
A. True
B. False
Who is correct?
Who is correct?
Who is correct?
A. True
B. False
A. True
B. False
Who is correct?
Who is correct?
A. Amps
B. Volts
C. Ohms
D. Watts
A. True
B. False
