I have the PMR handle bar switch which is single pole single throw.
I want to use it to switch between horn and air shifter which requires a single pole double throw switch to do it.
Flick it one way you have a horn, flick it the other way you have air.
Any input on how to convert a spst to a spdt switch using relays available?
could I use a 5 pin relay and take the output of 87a to one of them and 87 to the other?
JD
JD
