I am working with a pre-cut off the shelf set of pistons on an all motor build with rods. I had to fly-cut the exhaust recess areas to get better piston to valve clearance which is presently at .074 -.070 would have been better but less reliable...the current setting works just great.
Piston to head clearance is at .042. there is a window of .038-.042 but the latter is more reliable.
My delema is the intake valve to piston clearance is real loose .084 ish due to the deep precut recess's.
The intake target is .050 for this particular application but I cannot add material to this piston. Angle cutting the head is a distant thought. Use of a larger intake cam with slightly higher lift is an option, retarding the intake cam which is presently at 106 is a poor option as power would suffer.
My real question is to the guys more experienced than I, what kind of power if any would I gain by reeling that large intake gap in assuming the piston to head number stays the same.
I shoot for perfection with everything I do, this however has me slightly stumped. Are my hands tied here??
The clay impressions below visually show the above problem.
Please if you have not built a Hayabusa motor with your own measurements leave this thread alone. Thank you in advance.
Intake UPPER section...
