Mouse / Ruff Ryders
Hello!
I have an 04 with the following mods: PC3, Yoshi full exhaust, block off plate, Pingel Electric shifter(I am a left leg above the knee amputee) and a few other minor things.
After riding for a few minutes my issue starts. The bike, in 6th gear, will cut out at 90mph and back on at 85mph. The tac drops the temp gauge will spike and drop(not every time though) and me FI light then proceeds to start flashing until I turn the ignition off and restart the bike. I found that it will also in 5th gear cut out at 80mph and back on at 75mph. On occasion I can give it full throttle and I guess trick the bike to stay running for a few seconds and maybe get to 120/130 before it will cut out and wait till it get back down to 85mph.
I have checked and cleaned the injectors and tried disengaging the ignition kill from my electric shifter. I see on other threads people have had similar issues but not an answer to this problem. I've also seen that the kickstand switch should be checked... If that was the problem, why would it cut out at the same speed and back on at the same speed every time? My kickstand is tight and doesn't wiggle.
The engine when idling and when hold a steady throttle the rpms will sometimes to a once or twice quick surge. I have been told that that may be a PC3 issue. I'm more concerned with the engine cutting out at the present.
Thanks for any and all help!
