jtarantino
Have a 2004 Busa Limited that has been dying when clutch engaged at idle. Happens at normal operating temperature. Bike is totally stock. Any ideas? Thanks.
When I pull the clutch lever in is when it dies. Not always but am noticing it much more now. Bike idles at around 800-1000 RPM's - Thanks for the reply!when you say engaged do you mean pulling in the lever while in neutral or letting it our while in gear? If you mean letting it out, check your kickstand switch. Could be reporting it's down when in fact it is not.
Thanks so much for replying. Started a while back but only occasionally - did not give it much thought until Saturday morning. Between my house and Road America track for the AMA Superbike races the bike died 6 times - always when the clutch is engaged (lever pulled in). Died 5 times on the way home and twice today. I did take note of the idle speed by observing the tach and it seems to be registering between 800 - 1000 RPM's. Take care.Check your idle. It should be between 1200-1300 RPM to keep it from dying while coasting to a stop or pulling in the clutch, it's a common problem and you will probably have to adjust it regularly.
