willgetbusa
hi guys,
after hearing alot of positive feedbacks about engine ice coolant, i decided to try it. to say the least, i was disappointed with the product because the temp. gauge is still the same as with my old coolant. after the change, i let the bus idle for 15 minutes to see how engine ice holds up. the gauge went about 1/2 to 2/3 of the way towards the red area from the guage's half-way mark. this is the procedure i used: 1, drain old coolant 2, fill it up with 50/50 white vinegar and distill water, run it for 10 minutes, then drain 3, fill it up with distill water, run it for 10 minutes, then drain and tilt the bus side to side to get the last drops out 4, fill it up with engine ice and top it of. then run the bike at idle and the gauge was a little above the half-way mark at 10 minutes, fan kicked in, decided to let it run a little longer to see if the gauge will drop, nope, at 15 minutes, the gauge was getting close the red area so i just shut it down. i will take it out tomorrow and see how it does on the streets. i want it to keep the bike cool so bad, that's why i paid more for this product but now, i'm disappointed. might have to try heat tape next. so gentlemen, especially the ones that actually used engine ice, DID I DO SOMETHING WRONG with that procedure? or is it something else? any comments, suggestions, etc. would be appreciated!!!
