samw5
OK I'm not sure if it's a big deal but I've noticed that ever since doing my mods (this winter) the bike idle has been a bit low and the choke (idle adjuster... i know it's only supposed to rev RPM a bit) doesn't do as much anymore (doesn't seem to raise it very high).
I have installed a full Yoshi TRS line, headers are wrapped, TRE, small box, pair removed, and I got a PCIII USB with custom map (for Akra line with same mods).
Yesterday I was leaving work didn't warm up the bike as long as usual, removed the choke and it almost immediately stalled (which is ok i suppose) but then popped loudly when I tried to restart and didn't not right away (almost like it wasn't getting gas...). Waited 10 seconds and it fired back up no problems.
It's not really causing any problems but I figured I'd ask to see if those things are common with these mods or if I should check the plugs sooner than normal (I was going to wait a few hundred mi at least... probably done less than 200).
Any thoughts?
Any thoughts?
