squashgood
HI All,
I have acquired a kit car with a Hayabusa engine - having a few problems. I believe it is a standard Gen 1 Hayabusa engine. Normally the engine runs very lumpy at tick over - and does not have a lot of power. To my ear it seems a fuel starvation problem. I put a gauge in the high pressure fuel line - 45psi all looks okay. I played around with the pressure regulator (its not the standard Suzuki one) and found that if i increase the pressure to over 75psi the engine appears to start running fine. It ticks over fine, and I took the car up to about 80mph without any issues. My concern is that I believe a standard Hayabusa should run at 42psi - plus this is what the pressure regulator was already set to.
Engine doesn't look like it is running too rich, exhaust is not coloured and doesn't smell like an engine running rich. My thoughts are that maybe the injectors are blocked and need a good clean? Does anyone else have any thoughts that could help me. If someone has played with the ECU, would they ever remap to a fuel pressure as high as 75psi ( i assume this would need special injectors). My next step is to remove the injectors and give them a good clean. But as each injector has its own little filter - i struggle to see how the increased pressure would seem to suit all the cylinders? As you canb see I am a bit of a novice so any help gratefully received.
