Engine temperature
PaNDeM1C
Your Disease.....
When I ride, my temp gauge always stays right in the middle of C and H. Just wondering if that's normal for every busa. Is there actually a way to make it run cooler?
So, this isn't a problem... just something I was curious about. Thanks.
Normal is about a needle below midline. Ways to make it cooler are a Muzzy fan, Engine Ice (coolant) - some people add a second fan...
mine stays right below midline as well. i have 2 fans with muzzy blades. they dont make it cooler, they just cool the engine faster when in traffic and temps start to rise. if you want it to run cooler then get a lower than stock temp thermostat. i wouldnt mess with it though. suzuki R&D knew what they were doing when they made it.
Anytime I'm crawling thru city traffic mine stays right at the mid-line, stop and go it climbs one needle witdth above, and cruising speed stays one needle below.
I run a Muzzy Fan, Fan Temp Relocator mod ,Engine ice and have know problems with over heating in Fl.
mine also the same. will have a needle below when cruising at 90km/hr. will slightly a needle above when i met with traffic jam
+1
I use water wetter and distilled water 50/50 mix. I also have the alternate fan blade. Bike stays cool no matter how much I hammer it.
+1
