Habu
I searched on this topic and didn't find anything.....
I recently had my swingarm stretched 6 inches (welded extension). When I went to put everything back together, I found that my exhaust cannister touches the swingarm. I'm running a Yosh RS-3 full system (stainless with carbon fiber can), and the lowering links are set as high as they will go - which is stock length I believe.
It looks like the change in geometry causes this problem now that the bike sits lower due to the longer wheelbase. The angle on the mid-pipe is angled in towards the swingarm, which works fine with a stock wheelbase, but rubs now that it's lower and 6 inches longer.
I've considered a bunch of different options including: 1) having a local exhaust shop heat up the mid pipe and bend out the angle 1/2 inch, 2) installing a baffle in the mid pipe to create backpressure and running it without the cannister
Any other thoughts/suggestions?
Much appreciated.
Much appreciated.
