I have a Trac arm on the way and I'll be needing an extended brake arm for the rear. DOes any one know where I can get one? I would like to have it polished as well.
materials should be easy to come by at any local hardware store its about 1/8" thick by 3/4" wide aluminum banding i think is what they call it then just measure the length you need cut and drill holes aint sure what size holes they are but i think it was about 1/4" but check bolt size to be sure now some one else may have a better solution but thats what worked for me
the break lines folds forward all you have to do is take it loose at the master cylinder and twist it there are tabs on the cylander that hold the line in place i was told that i would have to cut one off but didnt its really easy almost like suzuki new you would be doing these things to the bike becareful how you re route the line it does sit close to the tire
