I've been using the extensions now for a couple years and it's been great. Although I am looking into a fabricated swingarm with the underbracing with an adjustable +4 to +10 over...
The only thing you have to know is that with them installed is that you are at a minimum +2 over. You can't set them to the stock wheel base. You're also limited to a max of +6 over or so.
If you want more flexibility say stock wheel base to +8 or more you'll need the swing arm done. If you just need a few inches then extensions are your answer.
