External Fuel System
Deez ballz
Hi Guys.
I have set up the fuel system on my bike with a Bosch 044 pump and its gravity feeding from the tank but the fuel lines aren't straight and it goes down from the tank and up to the fuel filter which is about 2 inches lower then the tank outlet, will this work effectively or do I need to re run it another way. If so what's the best way. Also will the fuel pump have any difficulties in this configuration?
Gen 2 2017
Thanks
Mine is also in the tail but I’m not running a botch. I read they do not like to pull fuel. That set up should work just fine I assume the pre pump filter is within specs for the pump.
