celticBandit
Hi guys, Anyone know how much oil it takes to go from F to E in the sight glass? Tried search but to no avail.
Thanks in advance
Tony
Thanks in advance
Tony
My oil changes have always been right at 3 1/3 qts. Maybe you have a pan full of metal shavings taking up spaceMy GenII not sure about yr of yours states in manual and 100 dollar service manual 3.3 qts.
But with that in it you could not even see oil in the window. A little at a time to bring it right up to F wound up being all 4qts with a filter change.
Dont know why they would say 3.3 when you cant even see it in window ?
RacerV if I had metal shavings taking up space it would take less and not more than yours..???
Might be yours that is full-o-metal
4 qts with filter change puts mine at the upper mark.
Thanks in advance
Tony
The answer is 0. You need to drain oil to get from F to E!
aaaargh...it was a trick question all along
or maybe he has a leak and just wants to know how much oil hes losing?
