Bowdoc
2005 with Brock hindle re-flashed ecu and power commander. The number two coil looked damaged deformed so I replaced it with another coil. Bike is still missing and pulling the plug shows that the #2cylinder is not firing. When I placed what I thought was the bad coil on another cylinder the missing gets worst so the coil was bad. I still only get the c25 code. I also changed the plugs and no change. Battery is charging so not problems there. I looked at all the wires and none look damaged. What are some other options. Could it be the ckp sensor? What are some other options. I have another ecu I could try also?
