F1 light is on
Busa Bill
Ok this is how it all began ..Sunday set my TPS and went for ride all is well came home yesterday and went for a little ride still no F1 light on so came home today after talking to the Cheese man and un pluged my battery pluged it in loaded a map and went for a brief ride all is fine turned around down the road and got on to it ,OH yea it feels great responce and all but I noticed that the F1 light was on blinking ,this was just after I layed into to her . So came home just a minute ago turned off the bike and started it again no F1 light ,hmmm.It seems to come on when I get on it .need some help guys dont like the looks of it thats for sure Im low in fuel but I dont think that would be the problem .HELP!!!!
I think you stumped 'em!!
I don't even have a good guess...
Sorry, I just saw your post for the 1st time...
All I can say is my Fi light came on once, and I still don't know why...
After turning the bike off and restarting it, the light has not come on again...
Sorry, I know that's not any help, but Someone will have a good answer for you...
David
I see the help coming in from all directions.
The only thing I could think of is the ecu didnt like the map. I would try reloading it again if you haven't already. Mine came on when a wire slipped out of the Fuel pump as well. Might wanna check that.
I don’t know, I put it up after that night and today pulled the cables off the battery let it set for a min. or two cleared the PC with 00 map, this should have put me with no codes on the ECM and a 0 map on the PC. Loaded a map set the clock and reset trip meters to 0 went for a ride hammered it a quite of few times never came on since ,WEIRD!!
, Anyway been looking for a good map to run on the girl ended up with a European map, seems to run all right. I have been up and down with maps and wasn’t to sure my bike liked the exhaust I put on it (Hindle full race carbon) and again up and down on buying something different, cant seem to make my mind up .I’m not a dragger I run low and mid most of the time plus I commute back and forth to work everyday if possible .I'm Venting ….lol
Mine did that when I put a custom map in my PCIII,
Reloaded the map that HMF sent with the exhaust and haven't seen the red light since, (knock, knock).
(Telboy2000 @ Sep. 21 2006,13:29) Have you checked to see what fault code comes up as a result of the F1 light?
Best place to start right there.
See what the code is and we can go from there.
I have a 2001 busa my light comes on every now and then still runs hard I was going to take the fairing off to see whether it had 02 sensors that might be causing it
I guess an out of parameter Air/fuel mixture would throw a code, especially under high demand, going too rich or too lean, I’ve got no experience with PC’s or maps.
