Fairing + Dash Panel Gap
ThatsMrGimp2U
Having a bit of a problem getting my dash panel to line back up with the nose and front left fairing. The tab on the fairing is not broken off, but whenever i push the dash panel into place it pops right back out.
How it should look:
and how it does look:
Anyone else have this problem? Help would be greatly appreciated.
Loosen up the three fasteners on the outside of the nose and make sure that the inner is seated in the groves on the inside of the nose... essentialy, take the upper inner back off and loosen those faseners... when you put it back you should haer a small snap where it seats in...
That is correct.
There is a "nack" to it. After a few times it's a ..well..a snap.
r8
Loosen every thing up to get it aligned and then when it's where it looks good tighten every thing back up.
