Fast Idle Adjustor
FloydV
Someone mentioned that there was a phillips head screw for the fast idle adjustor. Where is that located? It's not on the side where the regular adjustment screw is.
Not familiar with this screw....I used the main idle adjustment screw under the tank on the left side.
It's on the right side (sitting on the bike). Just remove the right side plastics, and then watch for the cam to move as you operate the fast idle lever.
Once you get it adjusted, a "dab" of silicone on the screw will keep it from vibrating loose.
Not sure if this will post correctly or not.
Page 4-66 of the Service Manual
I thought you had to remove the right side plastics, but according to this, you only have to prop up the tank. It's been a while since I messed with it.
<!--EDIT|stkr00
Reason for Edit: None given...|1130779679 -->
