Dracken
Hi Guys,
As the title indicates, I'm having trouble with my 2006 Busa. The bike is idling at a higher speed, around 1500-1600 RPM, than the 1250 it used to and when throttle is wide open or nearly wot (> 75%) the bike bogs down. I have only a few mods that would affect the engine: Power Commander 5, GiPro ATRE w/ Gear Display and a K&N Air Filter. Attached is a screen capture of the Power Commander Control Center w/ fuel mapping at idle, the bike had been ridden and was warm and the choke was closed when this was captured. There's no visibly extra smoke from the tailpipe and fuel economy is averaging around 40 mpg city/highway combined. Bike has about 48,000 miles on the odometer. I was thinking that there may be an issue with a fuel pressure regulator or a stuck open fuel injector, would tools to test this be available at an autoparts store for rent/loan or would only a dealer/mechanic have those tools? Any other ideas as what could be the cause? Between this and 2nd gear slipping under load (yeah, that known issue that Suzuki won't recall) I'm getting frustrated.
Thanks!
Dracken
Thanks!
Dracken
