Fat Man Mods
splcomplord
I'm about 275lbs. and when I punched the busa the other day it ripped off my license plate and inspection sticker, it was pretty funny to my riding buddie behind me. Anyway, I remember someone making their own sidemount brackets here, if anyone knows who that was I'd like to hear from them. I added swing arm ext. and didn't put lowering links, do I need them or should I adjust the rear shock to make stiffer? Please help.
p.s. I cut the fender off and put a good looking yet idiot made bracket and didn't think my busa would drop down so far when I punched it.(The reason for the questions)
PM the board sponsors, they can set you up with a heavy duty spring! That will fix you up!
(05BusaLe @ May 01 2007,19:30) PM the board sponsors, they can set you up with a heavy duty spring! That will fix you up!
Thats cool but, how do the people with lowering links and ext. swing arms punch it without hitting the tire.
i feel your pain..... im 300+ and i have soupy s links in between 2 and 3 in lowered changed out the undertail for a UFO and adjust the rear spring its a bit stiff but not too bad. i recommend a TMH undertail and if you have the money change the spring. oh and im also 4ing streched. i also made my own tag bracket that attaches to the left side pass. peg
