FI CODES Help
wht_scorpion
I wash the bike today every thing was going good. Before washing bike I started the bike and she was running fine I turned her off. Then started to wash her and I dryed her off. Went to go for a ride she would not start then the FI light came up. I removed the front and rear seat hooked the switch up and I cranked the bike for 4 seconds the FI light came on then I turned the switch on code C32,C33,C34,C35 came up turn the bike off. Then came across that the neg. battery cable was loose and the battery was losing power so now I have it hooked to the charge now. Can any one give me any idea if the battery trip the codes or do I have issues. Thanks for the help and ideas:banghead:
Probably no issues.
Once it dries out it will probably be fine.
Recharge the battery fully.
These are all codes for primary fuel injector circuit
All I have is a GenII manual but they should be same ?
See page 1A-84 in the manual here .
wait a min , what happened to genII manual pinned in GenII section ?
Maybe the fuel pump relay got wet? The relay is located on the left side behind the rear cowling (subframe cover).
Here good new the bike battery still charging but I went out and she started. No FI codes came going to take her out friday for a ride to see if those gremlins are out of the bike or it could of been fate telling me not to go out. I just had a issue. thanks guys get back to you to tell what happens friday.
It the ride came out good no FI light. She ran good. Do you guys thing I should check the spark plug she is running fine.
