If your tire is 190/50/17 (width in mm/height % of width/rim size in inches)...
then your circumference is (190*(50/100)/25.4+17)*pi [pi is 3.14 or so]...
this gives:
Tire Circumference: 76.91 (this assumes no tire wear!)
The formula is...
MPH=RPM/(gear*primary*secondary)*circumference/(5280/12)*60
primary 83/52
secondary 40/17 (rear/front sprocket)
gears and MPH @ 4000 rpm (actual - not what you see on your speedo)
1 - 34/13 - 30
2 - 31/16 - 40
3 - 29/19 - 51
4 - 27/21 - 60
5 - 25/22 - 68
6 - 24/23 - 74
with 42/17 (42 rear sprocket)@ 4000 rpm now gives...
6 - 24/23 - 71
this gives:
The formula is...
primary 83/52
1 - 34/13 - 30
2 - 31/16 - 40
3 - 29/19 - 51
4 - 27/21 - 60
5 - 25/22 - 68
6 - 24/23 - 74
6 - 24/23 - 71
