first mods help
Jazzcatcf
I still need to save up some cash but after a little research I like brocks.So what I wanted to do was get pipes maybe alienhead.What do you think are his best pipes.I wanted to get his TRE and of course power commander,and new air.Would that make for a good start.Again this is still months away but I like to know im on the right track.
Skip the TRE and PC, go for a clutch mod and i like his gen3 canisters. Find yourself a ECU dyno tuner and using the money saved on the PC and TRE
It really comes down to what you want. He has a lot of information on his pipes. I would agree with no TRE, no PC and tune / tweak the ECU.
hmmm I dont know anything about tweaking a ecu.Is that basically throwing the bike ona dyno and hooking up to the ecu like a pc and messin with the numbers?Thats better than a pc?So I would get pipes and air then go straight to the tun ing guy and hell just do the ecu?is it the existing ecu or a new one.Also would it just be better to bypass all that and just get a turbo installed or is that overkill?I just want to get the most out of my bike.I would be looking at 5 grand at most but more like 3 grand
Boostbysmith.com, site sponsor, the ECU Editor, $208, does everything. PC can only map fuel(and ignition, which you don't need). ECU Editor can turn off pair valve, top speed limiter, open gen2 secondaries full 94%, and alot more! As said, does everything. Good tune $300 to $500 average depending on where you live. Air filter, $70, full exhaust, new prices from $700 to $1800 average, countless out there, depends which you want. Get some better brake pads, stainless steel brake lines, both around $200 to $250. You'll still have some cash.:thumbsup:
I like my CT1 exhaust............... The tre is a waste. ECU reflashing is easier than it sounds, Boost by Smith has videos to walk you thru everything. It does more than the PC and is cheaper!
