shadetree57
This is the first job other than oil changing and chain adjustments. Those were on mostly non profit bikes. This is a 750 Honda spirit. The front head has got to be replaced and I think it's because of a defective pipe. It had an exhaust leak so the owner tightened the pipe a little. When I took the pipe off the collar under the flange had broken loose from the pipe. When he tightened it it wedged in the head and broke a piece out. If this bores you I appologize but I'm happy to use the shop for more than my own use. You can see in the pics what the problem was. Thank you so much for your undevided attention.
