first time ever
allmotor01
Hi every one took my bike 2 the track 2 see how it went. boy did it go. 1st run ever 10.44 @ 141mph, by the end of the night i was down 10.186 @ 140mph. wich i thought it was good. ill lower it soon & see how i go. Should go quicker i think? cheers all motor 01.
Take five and remove the mirrors!
"Evry`lil bit helps!" said the ole woman, as she peed into the sea! :laugh:
Hi people thanks 4 all the cheers,as 4 the bike it had a couple of home made mufflers i made but it was running bit lean up top. So i put the original pipes back on & next time went faster.What are the times 4 something similar over there. no mods yet When & if i get a 1.7 60ft & i get 9 som... then ill get some work done to it.
Keep working on you skills first and foremost; low 10's are respectable and yes you should be able to dip into the nines :beerchug:
hi & thanks again i went out again with the oem pipes.i got best 4 the night 60 ft1.844 4.492 6.681 116.63 mph 10.001 143.62 mph . Other run got 1.794 60ft, nearly there. stock height &clutch time to work on it.
Very nice! :beerchug:
Get that 60' down and you'll be in the 9's very easy... :thumbsup:
Easier said than done, you with the shifter :laugh:
I remember trying to get my foot up :laugh:
I saw in the one pick that he came off the line with his shifter in place :beerchug:
get the 60ft down to about 160 thats where it all comes from in racing take off is everything but for first time not bad:laugh:
good ay people i weigh 156lb with no gear, theres no air ****er & no mods. it will be lowered 4 next time +shift lights see what happens then, havent worked out the launch yet.
