Fitting buell pegs
Mojave Mike
Got my Buell Lightning pegs to lower the peg height, and see they need a little filing to fit the slot...but what about the pin size ? The Busa is much smaller in dia, so did you drill out the Busa bracket and fit the Buell pin ?
Mike
never done it -- but i think you need gm bushings (pn 38375) to make them fit (without drilling your bike)
you can also use small piece of fuel line to sleeve the pin.
it's easy, cheap and will never rust.
take the pin to any autoparts store and find a line that has an I.D. that matches up.
<!--EDIT|BusaCruise
Reason for Edit: None given...|1153105332 -->
