WrongWheelDrive
Just got my ecm back from Moore Mafia - is there anything you have to do or is it just plug it back in and it's good?
You do not have to remove the O2 sensors you just need to unplug them at the other end. The left side is a pain because it's under the tank. The right side is much easier to get to. You don't have to remove the side fairings, but you need to loosen them up a to make room. I believe it takes 3 key cycles and the warning lights go out.Ok so you have to completely unplug and remove both o2 sensors? I got the Alra exhaust. It came with the bungs but I took them out and put the O2 sensors in.
I emailed Chris Moore and he said just plug them ecm in and after a few rides all the lights would clear, no mention about removing the O2 sensors.
Awesome video thanks! Saved a lot of time instead of completely removing the plastics again.You do not have to remove the O2 sensors you just need to unplug them at the other end. The left side is a pain because it's under the tank. The right side is much easier to get to. You don't have to remove the side fairings, but you need to loosen them up a to make room. I believe it takes 3 key cycles and the warning lights go out.
I didn't put this in the video, but I had to reset my RPM shift light settings. The shift light was turned off. Just a heads up you may have to reset it.Awesome video thanks! Saved a lot of time instead of completely removing the plastics again.
