Flashed: to be or not be
bonestock
Trying to decide which is better overall ecu flash for an 08 Busa or powercommander 3 or 5 with nos 40 shot i have to buy the hub with map switch still so I want to spend my money wisely any suggestions
Save the money on the PCV and Autotune system and do the ECU Editor, if it can work to do what you want.
Go with the flash i did works perfect but be AWARE upgrade fuel pump and DON'T go with a 40 shot without springs and stainless steel valves:thumbsup:
heres the pluses+++ with ecu editor, ecu nitrous/turbo progressive control, air shifter kill, you can remove pair valve, injector balanceing, timing, fuel, map switching,rev limit ,limit remover and much more. all plug and play no mess,trouble free i use them all.
