flooded 05 busa
excitebike
i bought an 05 busa flood damage and everything lights up and even starts with some starting fluid but i'm not getting any fuel from pump. fuses are good and plugs are not corroded, does anybody have a pdf manual or wiring diagram? or suggestions?? thanks email captdave06@hotmail.com thanks again
First thing I would do is strip it and go through every nut and bolt. Clean every part and have the engine checked out by a pro.
P.
I agree with Postal clean and dry everything. Saltwater is not good for equipment or anything else so if was in saltwater you need to get it washed and cleaned quickly. There is a download of the service manual under do it yourself, download it and check it out. So many things could be wrong cann't even begin to guess.
Does it prime itself?
