Once I put a .010" in mine, I never had another problem with the FMU.Thanks for the replies. I got some .010 shim stock from a machine shop today. Richard at RCC said that the .005 shims bent due to boost I was running and recommended .010 shims.
Did you replace both of the shims or just one?Once I put a .010" in mine, I never had another problem with the FMU.Thanks for the replies. I got some .010 shim stock from a machine shop today. Richard at RCC said that the .005 shims bent due to boost I was running and recommended .010 shims.
