Frame sliders installation
fsusux
Banned
The sliders i've seen so far all say that the skins must be modified for proper fit. What kind of mod is needed?
you have to drill out the side fairing. Ther are a couple of ways to mark and drill. I think there is a thread in mods about that. Hope that helps
Look under mod discussion section and hit the search button
+1
look for frame slider modifications-u need 2 mark holes from inside fairings w/sum sort of punch, then cut hole in fairing with drill n big bit(don't forget masking tape on outside of plastic), smooth out ruff edges n install sliders. takes bout 20-30 min a side easy.
good luck
