Frame Sliders
cbibb
Getting ready to install my frame sliders amongst other things and want to make sure I am using the right bolt. It is the top front engine mount bolt correct? There is is in the front and one in the back up top. I am going to use the laser pointer meathod. Thanks for the help. Chris
These are the correct bolts to use...
Cbibb, just make sure to start with a small hole first then if you need to adjusted it a small amount you can.
Stealership charged $100 to install and did a great job. They screw the plastic up and they pay, you screw it up... well you know
Odd how the lines are different on each side, thought the bike was pretty square until they installed them.
