From 16/42 To 16/11
ALLshow.NOgo
Yes that is correct.  Changed out my rear sprocket the other day and had only 11 teeth one 1 side of the sprocket.
Those of you who remember me posting about 6 missing teeth, well this was the result of a loose chain.  I remember several times getting on it and hearing the chain slip like it jumped teeth, or in this case, demolished them.
The teeth that were left where in bad shape, about to give way; as they were filed down 'width' wize.  If I continued to drive like I do, (1st, 2nd power wheelies and mad excelaration) I probably had a couple hundred miles before something happened.
I have a new 42 sprocket on now, in steel as in opposite to the aluminum take off.
I know I come up with the weirdest and worst chain/sprocket problems but I still post them just incase there are some other nuts like myself out there this could help.
I realized last week that I need a new rear sprocket because I'm missing 8 teeth. Where is the best place to get a 42 or 43 teeth steel rear sprocket?
(1 BAD 2K @ Dec. 18 2006,06:17) I realized last week that I need a new rear sprocket because I'm missing 8 teeth. Where is the best place to get a 42 or 43 teeth steel rear sprocket?
I would check with Charles at Street and Track. I just got mine from my trusted local shop for 40$ at 42tooth
Damn fellas...you guys ain't the lick of a snake...that's cracker talk for too lazy to maintain your ride.
You must have never adjusted your chain...as soon as one tooth is even close to gone I'm getting a new sprocket.
Best of luck the second time around.
I'm speechless, well almost. Those bikes need some tender loving care..........
