Front Axle Size
_WOLFMAN_
Canuck Ground Pilot
Just wondering if some knows or close to their Gen 3 Busa what the inner diameter of the front axle is? I know the nut size but looking for the actual hole size through the middle of the axle.
25mm
I had to return my Motion Pro bearing puller because they didn't have a 28 mm for the rear but it did come with the 25 mm for the front.
That's the outside diameter of axle. I am looking for the the size through the center of the axle.
My apologies Deano I read that wrong.
I'll get off the plane around midnight and I'll check that when I get in the door if no one replies by then.
