Front end misalignment
toddda
I laid my bike down a while back and am finally able to take the time to put it back together.  I have a problem with the front end.  The handlebars are pointed straight but the front wheel is cocked slightly to the right.  I removed the wheel and forks and pulled both fork tubes out to see if they were bent.  They do not appear to be.  Do any of you have any idea what else may be causing this?
Any help is greatly appreciated.
The top clamp has rubber bushings in it. You may have to loosen the bolts up and reset them. They may be tweaked.
your top and bottom clamp could be out of aline.
Losen your clamps just a bit. Just enough to rotate your forks but not to let them fall out of the clamps. Spin the front wheel and then grab a hand full of front brake. This will pull the clamps strait again. Tighten down and enjoy.
Josh
Ryders Connection
