Front end rattle
A'Busa'd
My bike has developed an annoying rattle in the front end. I can hear it whenever I go over rough pavement. Sounds like it's coming from inside the front fairing. Without taking everything apart, I've checked everything I can and all seems to be ok.
Any suggestions?
check all your bolts to make sure that everything it tight.. did you have any front end maintence done before you started hearing the rattle?
I had the same thing at different times. Once the panel underneath the headlight assembly did not have the push pins properly connected - easy fix.
Another time the bolt holding the front fender on had fallen out. Another easy fix, though the dealer charged $5 for the bolt and the ferrule!
Or it could be the windshield. I haven't done that one yet but I've read that if you remove it and put a layer or two of electrical tape on the front edge the rattle stops.
Hope this helps
Common complaint...It's your steering damper..
They rattle a bit over bumpy surfaces.Nothing to worry about..
