Ok, so I went to the track day, everything went well, but the vibration was still too much to really explore the full potential of the Busa as a cornering machine.
If unfamiliar with this vibration issue, refer to the link below..
PREVIOUS THREAD LISTING PROBLEM....CLICKY
Yeah, vibration is still between the ranges of 40-60mph, mainly noticed on decceleration, but prominent in that range when accelerating and holding constant speed there.
Went to a local shop today and we pulled the front wheel off and put a dial indicator on both the wheel and the rotors...here are ther results.
Wheel...Everything straight and OK
Right rotor...off 10/1000 th's
Left rotor...of 9/1000 th's
My question to the masses is, what, if any, is the allowable amount for a rotor to be "off" before you notice problems? i mean, is this like a no room for error type of problem? Any deviation gonna cause this?
Like before, under braking, i DO NOT notice any vibration, unless in those ranges, and the intensity is the same in that range whether braking or just deccelerating without hands on the bars.
Guy at the shop says that the wheel/tire is "almost" balanced, but it is just ever so slightly off. Would this cause the head shake? Should i take it tomorrow and have a reputable shop just check and see how far out of balance it is, if any?
I am very tempted to remove the brake pads and brake lever and take off down an empty street, and just see if it does it. If the vibration goes away, I guess we will know the rotors were to blame. if NOT, back to square one!
Just spinnin my wheels here guys/ladies...
Open to suggestions once again.
